Too much tubular glue on my rim...
Results 1 to 25 of 28
    Apr 2012
    So I tried to glue my tubulars on my rims myself.
    Details-
    Tire: Vittoria Corsa Evo CX
    Rim: carbon fiber 88 deep rim w/ carbon brake area
    Glue: Vittoria Mastik One
    What I did:
    I put four layers of glue between my rims and my tires. I let each layer dry from 8hrs to 48 hours. The layers get getting thicker each go-around.
    I then put one thickest layer on the tire and the rim just before I put the tire on the wheel.
    Glue started getting over everything. My hands. My clothes (luckily I was wearing an apron), and the rim. I tried to get most of it off but I couldn't see it.
    I let the wheel to dry for three days.
    The problem:
    GLUE IS ALL OVER THE RIM and ALL OVER the sidewalls of the tire.
    How do I clean up my mess? Will I take too much glue off if I scrape and pull glue off with a butter knife? Will I damage my rims if I use acetone? What about soaking in water?
    It's a mess.
    Suggestions are welcome.
    Also, what the heck should I do to blue on the second tire to the back wheel? How do I make it have enough glue to be a strong bond, but not so much that it's a total mess?
    Pictures will be coming soon.
    Jan 2011
    Find out from the wheel manufacturer but acetone should work.
    The only way I think you can actually make that bad of a mess is if you are making your layers WAY too thick and/or are simply not being mindful of not touching the glue as you work the tire/rim.
    Apr 2012
    Quote Originally Posted by forge55b View Post
    Chinese rims with 3d coating. Thoughts?
    Can I cut some off with a butter knife, or will I damage the rim?
    I have no idea how to be neat about it.
    There was glue all around like spider webs. It got in my hair.
    I'm going to try to make THIN layers this time around. I've got one layer curing on my new tire right now. a THIN layer.
    I hope not too thin. This is ridiculous.
    Reputation: JimP's Avatar
    Dec 2001
    Naptha (lighter fluid) will dissolve the glue without hurting the wheel or tire sidewall. Wet a rag with naptha and rub the wheel or tire. It helps to use a piece of white cloth because it will change to the color of the glue as it picks up the glue. Keep using pieces of clean rag and naptha until the glue is completely removed.
    Jim Purdy - Mansfield, TX
    Jun 2007
    Rules for glueing tubulars:
    2-3 thin layers on rim. 2 coats on tyre, thick enough to be fully penetrate basetape. 24 hours between each layer. Stretch glued tyre for at least 24 hours. Final coat on rim only.
    Banned forever.....or not
    Aug 2002
    The first time I glued up a set of tubies, I got glue all over. I got it on the tire sidewalls, on the rim walls, my hands, and my legs. To make matters worse, I was doing this outside on the front step. Having glue smeared hands, I knocked the wheels off the steps, into the newly cut lawn. I never got all the grass off the tire sidewalls.
    It looked bad.
    Dogbert.
    I>U
    Feb 2002
    Aromatic solvent
    Quote Originally Posted by xrodolfox View Post
    Details-
    What I did:
    The problem:
    It's a mess.
    Use solvent like xylene or toluene (aromatic solvents). Acetone is useless comapred to these solvents, as is lighter fluid. Look at the labels of some of the paint thinners at your hardware store. Things like Goof Off work as well. Wet a rag and use that to rub off the glue - that way you are not saturating the rim. No real need to remove the glue fromt the tire except for cosmetics. You risk damaging the tire.
    'brifter' is a lame word.
    Quote Originally Posted by elbee View Post
    ^ this ^
    don't EVER put a coat on the tire right before you mount it. how could you not get glue all over the place if you do that? and like elbee says, re-stretch the tire after the glue is dry.
    I work for some bike racers
    and a bunch of skateboards
    Reputation: ms6073's Avatar
    While those who glue tubulars on a regular basis will probably scoff at this suggestion, when I mount tubulars, I apply inexpensive vinyl electrical tape to the brake track on both sides of the rim before applying glue. This does a good job of keeping glue off the rim and once the tire is mounted and the glue is dry, I can peel off the tape and use on the aforementioned solvents - Xylene is sold under the label Klean-Strip and comes in in 1-Gallon cans found in the paint section at Home Depot - to easily remove any glue residue but you need to use them in a very well ventilated workspace.
    There may not be an 'I' in team but there is a 'U' in suck!
    __0
    _ \ |_
    (O)/ (O)
    weird huh?
    Reputation: cmdrpiffle's Avatar
    Mar 2006
    Quote Originally Posted by ms6073 View Post
    Scoff? I wouldn't mount sew ups without taping the rim braking surface. I've always used masking tape (may try electrical tape) and I also wet mount the last coat on the tire (cyclocross tires so it's a total of 5 coats, 3 on rim, 2 on tire) that tends to get a bit messy some times.
    Otherwise like others have said, stretch em on an old rim for at least a day, (clincher rims work fine) and if road wheels, no need to wet glue the final coat on the tire.
    Feb 2002
    Glue on sidewalls
    Quote Originally Posted by cmdrpiffle View Post
    I rode tubulars for 30 years and once I got the hang of mounting tires, I NEVER got glue on the rim sidewalls and so never needed to tape anything. I can't really see why this would happen but apparenly it is in the nature of your technique to need to mask off the rim sidewals.
    i will never understand people thinking there needs to be a wet coat on the tire...makes no sense. if you have glue on the rim, what's the point? once the tire is on the rim, there is tire>glue>rim either way...
    wet glue on the tires=mess
    wet glue on the rim=no mess (or less mess if you're bad at mounting tires)
    Jul 2011
    Conti says put a final layer on the tire just before mounting it on the rim, as well as a fresh layer on the rim itself. Most others seem to forgo the final layer on the tire.
    weird huh?
    Mar 2006
    You rode sew ups for 30 years and never got glue on the rim sidewalls
    ummm, ok
    Feb 2007
    I'm going to have a go at my first tubular gluing experience next week. So...
    Monday, tape up brake tracks, glue on rim and tire.
    Tuesday, next layer on rim and tire.
    Wednesday, mount dried tire on (another) rim.
    Thursday, glue on rim, mount tire
    Friday, and on the fifth day, the good Lord rested and partook of his 6 pack, and saw that his work was good...
    Does this sound right?
    Dec 2001
    Quote Originally Posted by gordy748 View Post
    Conti recommends mounting a new tire on a clean rim for 3 days to stretch it before gluing. I find it easier to glue in the morning and remount on a clean rim every evening to help keep the tire stretched.
    Reputation: stevesbike's Avatar
    Jun 2002
    Quote Originally Posted by iclypso View Post
    The Conti instructions only work if you have a Bavarian powerlifter doing the install:
    that should work fine. i don't think you need to stretch the tires any longer than that. usually a few hours at 70-80psi works fine.
    ummm, ok
    i mount well over 100 tubulars a year and i don't get any glue on the rims. easy. what makes you think it's so hard?
    May 2012
    Dec 2002
    Gonna be honest here but I think a lot of people are making the gluing thing to be more arcane and "artsy" than it has to be with multi day drying periods. The friend who taught me wrenched for more than a couple Conti and Pro Conti US teams. He uses Mastik one. His process? 2 coats on each (dry to touch in between but still "tacky") then one coat on the rim and mount the tire. Takes about an hour for two wheels when you good at it. If this kept tires on wheels on descents in the Mountains of North, Central and South America at speeds most of us would consider crazy, I think it is pretty safe. The trick is to make sure each coat is not too thick and even, that's about it.
    Far better is it to dare mighty things, to win glorius triumphs, even though checkered by failure... than to rank with those poor spirits who neither enjoy nor suffer much, because they live in a gray twilight that knows not victory nor defeat.
    Theodore Roosevelt
    weird huh?
    Mar 2006
    Good, you've got skills. Mine pale next to yours I guess.
    weird huh?
    Mar 2006
    Quote Originally Posted by badge118 View Post
    You're prolly right, everyone has a technique. I only run tubulars on my CX bikes, and I run them around 30psi, sometimes lower. That's why I use the glue system I use. I have rolled exactly one tire ever, and it was old glue.
    Oct 2011
    That's exactly how I ended up doing it on a regular basis. It takes just a few hours in the evening for the 2x2 plus 1 coat, and in the next morning they are ready to ride. So far, no rolled tire.
    Feb 2002
    Snark?
    Do I detect some snark in that comment? If not, my appologies, but you ribbed me for saying I didn't get glue on the sidewalls, and now it seems like you're ribbing cxwrench. Not a great way to make friends if that was your intent. Just saying.
