Tubeless Tire Pressure
Results 1 to 25 of 50
    Jun 2019
    For those with road tubeless what psi do you run?
    I知 riding a new Roubaix with Roval C38 wheels and went tubeless with S-Works Turbo Pro tires 28mm. First set of road tubeless for me and looking for suggestions on psi to run. I知 approx 170 lbs. and so far been riding somewhere between 70-80.
    'brifter' is f'ing stupid
    I refuse to use road tubeless anymore but when I did I used the exact same pressure as my clinchers because I didn't over-inflate the clinchers. I weigh the same as you and would be around 70 rear/60 front w/ 28mm tires. Depends on the width of the rim to some degree IMO. Narrower rims I'd bump up a little, wider I feel like I can run a little less pressure. Mess around with the pressure and see what you like. Go down really low so you know what they ride/handle like.
    #promechaniclife
    Cleavage Of The Tetons
    Reputation: rideit's Avatar
    Feb 2005
    CX, just out of curiosity, are there any technical advancements that would have you try tubeless again in the future?
    I have been happy with it, and refuse to ride tubes on my gravel bike, which I ride on some gnarly terrain.
    Reputation: Srode's Avatar
    Aug 2012
    Quote Originally Posted by golfnbike13 View Post
    I weigh about 180 and have been running 60 front 65 rear on 28mm tires which measure 30mm on the rims which have 21mm internal width. I've tried 70 front 75 rear and noticed a difference in the ride but not handling so settled on the lower pressures. I think you can run lower if you want a smoother ride. Here's a link to recommended tire pressure starting points from Enve for tubeless on their rims. (see the bottom of the page) https://www.enve.com/en/products/new-ses-3-4/
    Quote Originally Posted by rideit View Post
    Why? That's the perfect place for tubeless tires. I know lots of people that ride / race gravel and nobody I know rolls tubes.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    changingleaf
    Aug 2009
    If the pump is accurate I think 60/70 would be better.
    Reputation: velodog's Avatar
    Sep 2007
    Quote Originally Posted by changingleaf View Post
    This is the point. I've pumped up tires to 50lbs on a pump and they were "right" and I've inflated tires on another pump to 50lbs and they were rock hard. One needs to find the ride that suits them and pump to that pressure on that pump.
    Too old to ride plastic
    Feb 2005
    I think you misconstrued...I refuse to ride tubes on the gravel, not the other way around. I ride tubeless on all of my bikes, even the commuter.
    Reputation: davesupra's Avatar
    Jun 2017
    I have 25mm in my road bike, and run around 60f 70r, I weigh 175 lb.
    Joe Biden: a case study in plastic surgery disasters.
    Liars often accuse you of lying. - Steve Maraboli
    Aug 2012
    yep, I missread it, not enough coffee this morning before I started reading I think!
    Gravel Rocks
    Trek Domane
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Probably not. The thing that really pissed me off was getting a big cut in a tire. Tight tires, sealant, booting the tire...a big mess. If I'd cut a clincher it would have been easier to take the tire off/remount it and I wouldn't have had to deal w/ sealant getting all over everything on the side of the road. I'd also given up some ride quality going tubeless as the tires are by necessity thicker to hold air. There are some tubeless tires available now that have a pretty good ride but I'm sure they give up some durability. There is no change to lower pressure when using tubeless for me as I never over-inflated clinchers to 'avoid pinch flats'. I don't do any riding on really rough terrain w/ my cx/gravel bike so pinch flats are unlikely. If I'm going to do a mtb ride I'm going to do it on a real mtb.
    #promechaniclife
    Jun 2019
    Is getting a little sealant peeling off between the tire and rim any issue?
    I知 assuming that痴 what this gum like stuff is.
    Tires are holding air fine.
    Nope.
    #promechaniclife
    Feb 2013
    Have to agree with this. I have less flats but when I had one it really was difficult getting tire off of rim. Bead was on there. Almost gave up.
    Reputation: OldZaskar's Avatar
    Jul 2009
    I'm living on the edge... have tubeless tires that I KNOW I won't be able to get off the rim out on the road. It'll be an Uber/wife/kid rescue call.
    Over the weekend, a friend and I worked on a tire for 20 min. in the garage trying to unseat a tubeless tire. The beads were so perfectly seated in perfectly matched grooves, it took a butter knife, two metal-core tire levers and four hands to get that tire lose. We were taking that tire off because of a sidewall cut.
    I'm with ya cxwrench... the risk and hassle is outweighing the fewer flats.
    Feb 2013
    What works good if you are home is a vice. Squeeze tire in a vice right at rim. Crank down tight and twist rim. Pops right off. Did this the other night with a tire that would not come off. Had plastic jaw covers and made sure I didn't touch rim. Plus side is if you get a flat probably have a better chance off tire not coming off and screwing up expensive rim.
    Jul 2009
    sasquatch16 I will definitely give that a shot next time. Thanks for the tip!
    It does seem the tire engineers are 100% laser focused on 1/2 of the tire use/process. The fact that we're using bead jacks (great tool fromm Kool Stop), butter knives and bench vices to mount and remove tires is a pretty sh|itty sign.
    changingleaf
    Aug 2009
    What rim and tire combination are you using?
    Quote Originally Posted by OldZaskar View Post
    I had to use this knife, which I keep sharp enough to shave with, to get a couple Schwalbe tubeless tires off some Zipp rims that belong to a certain retired major leaguer who hit a great many HR's for the Giants. While he watched. Talk about pressure! Good thing the knife was so sharp. No way in hell I could've removed those tires on the road...no chance.
    #promechaniclife
    Feb 2013
    Schwalbe Pro One on a Giant SLR1 wheel
    Feb 2013
    Nice knife and Rifle
    Quote Originally Posted by sasquatch16 View Post
    Thanks! Those knives are an exceptional value.
    #promechaniclife
    Nov 2002
    This has never happened to me, but what is the cause, I wonder? Some people just don't have the grip strength, but do some sealants glue the tire to the rim? I've only used Orange Seal and have never had this problem.
    tlg
    tlg is online now
    Reputation: tlg's Avatar
    May 2011
    I've been running Schwalbe Pro Ones for a few years now. Never had a flat yet. I had one sidewall slice from hitting a rock. Booted the tire, put in a tube, and finished my ride.
    I've gotten Pro One's off several rims easily by hand or with one tire lever.
    Sep 2011
    i'm with CX, tubeless for road makes little sense, doesn't have the same benefits as on mtb.
    One time I got a sidewall cut and it was a messy experience fixing on the road.
    Second time was a puncture-seal that got popped open once the tire had worn down a bit more after some mileage, and the puncture would never seal again after putting in new sealant. Ended up putting in a tube for use (which now makes the tire a non-tubeless tire, so it's a bad investment since the tire had was not even half worn yet).
    Jun 2017
    I'm in the same boat, I have one wheel that I taped tubeless and I don't have any concerns removing that tire on the road, but my other wheel has a bontrager tubeless rim strip that is so tight there is no way I'll get that off. I'm guessing when it's time to remove/replace that tire, I'll be cutting it off.
  1. Replies: 3
    Last Post: 05-18-2017, 05:22 PM
  2. Tubeless Tire Pressure
    By Weav in forum Wheels and Tires
    Last Post: 05-07-2012, 06:48 AM
  3. tubeless tire pressure?
    By fishman473 in forum Cyclocross
    Last Post: 11-15-2009, 06:08 PM
  4. Max Tire Pressure by tire size for Mavic Rims
    By merckxman in forum Wheels and Tires
    Last Post: 11-27-2006, 03:53 AM
  5. Best tire pressure/tire size for tar&chip roads
    By Thor in forum Wheels and Tires
    Last Post: 11-07-2005, 10:36 AM
