Tubeless tire pressure drops to nearly zero when I connect the pump
Results 1 to 8 of 8
    Aug 2015
    I just got my first set of tubeless wheels/tires for any of my road bikes. I have a lot of experience with MTB/CX/gravel tubeless but never road.
    Anyway, if I connect my pump to the valve, air starts hissing out of the valve stem/rim interface area until the tire is basically flat. In previous experience, this means that there is a flaw in the tape job but this time I used Roval rim strips so there's less chance for an imperfect seal like with tape. If I pump the tire back up, it holds air for days at a time but I'm wondering why it basically goes flat just by connecting the pump.
    All of the equipment that I think matters--Light Bicycle AR56 rims, Roval rim strips, Orange Seal valve stems
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Do you have the nut installed and tight? My guess is when you put the pump head on, you're pushing the valve stem up and letting air escape. Once it's inflated, there's enough pressure to keep it seated and sealed.
    Reputation: Srode's Avatar
    Aug 2012
    What TLG said.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Aug 2015
    I put it on as tight as I have in the past for other setups but I'll try tighter. The Orange Seal valve stems came with o-rings to put under the nut (not something I've seen before) so maybe that's causing friction that makes it feel more torqued than they really are.
    edit: that worked. I had to go tighter than I usually would but sure enough that fixed it.
    Oct 2013
    The pump is leaking the air, not the tire or valve. I have a pump, it just leaks, you have to pump fast and remove the connector fast.
    BANNED
    Aug 2015
    It ended up being the valve nut. I had it tight but when I cranked it as hard as I could with my fingers instead of the usual "snug", the issue stopped.
    'brifter' is f'ing stupid
    Once again you claim to know what the problem is with big time confidence...once again you're wrong. If wouldn't give you **** if you just said "Good chance it could be the pump, it's happened to me" but you always claim to know exactly what the problem is because you can only see your own experiences. "My pump leaks air, therefore eveyone else's must too so that's the problem". If I were that narrow minded I'd never get anything fixed, nor would I ever learn anything.
    #promechaniclife
    Oct 2013
    Well, he did say he was really experienced, I guess he wasn't either, ... your right it's all my fault.
    BANNED
  1. Zero plus zero equals zero.
    By oily666 in forum Politics Only
    Last Post: 06-10-2016, 01:30 PM
  2. Bike Tire, Schrader Valve, Removing Pump Head, Pressure Loss ?
    By TomBrooklyn in forum General Cycling Discussion
    Last Post: 06-01-2012, 12:03 PM
  3. Pump/tire pressure
    By Smoke2 in forum Beginner's Corner
    Last Post: 08-07-2011, 04:00 PM
  4. Pump, pump, pump it up!
    By catzilla in forum The Lounge
    Last Post: 11-25-2008, 12:57 PM
  5. Tire Pressure and my bike pump!?!
    By FuJiRaCeR19 in forum General Cycling Discussion
    Last Post: 08-25-2006, 09:41 AM
