Which tubeless tires
Results 1 to 25 of 39
    Reputation: davesupra's Avatar
    Jun 2017
    I picked up a set of tubeless ready wheels for my road bike, and I'm deciding which tubeless tires I want to run. I think I've narrowed it down to either the schwalbe pro one, or the Conti gp5000 but I suppose I could possibly be convinced otherwise. Has anyone here ridden both that could give their impressions? I think I'm prob going to get 25mm width, 28's will fit but they are a snug fit in the forks.
    Thoughts?
    Thanks,
    Joe Biden: a case study in plastic surgery disasters.
    Liars often accuse you of lying. - Steve Maraboli
    Bianchi-Campagnolo
    Reputation: kbwh's Avatar
    I've used the Pro Ones (on Campag Shamal 2wf) since they came out. I like them a lot, but they are a racing tyre so fatigue life is not long.
    They do anything just to win a salami in ridiculous races. I take my gear out of the car and put my bike together. Tourists and locals are watching from sidewalk cafes. Non-racers. The emptiness of those lives shocks me. It was the illest of times, it was the dopest of times. And we looked damn good. Actually the autobus broke down somewhere on the Mortirolo.
    Jun 2017
    Quote Originally Posted by kbwh View Post
    Thanks for the reply. When you say "not long", what do you mean? 1000 miles?
    Feb 2002
    Please explain what you mean by "fatigue life" when it comes to bicycle tires. Tires wear out, they don't fatigue.
    Reputation: upstateSC-rider's Avatar
    Aug 2004
    My current fave is the Pro One, fast and supple, but I've also used Hutchinson Fusions without a complaint and have a Hutch. Galactik (?) in the wings ready to try. I've also used Giant Gavia's, and though they seem to wear well, they have more of a dead feel. I'm really excited about trying the GP5K TL when I can find a deal.
    In reference to the Assault on Mt Mitchell...
    Quote Originally Posted by merckx56
    The easier solution is to find a biker bar in Spartanburg the night before, go in and pick a fight. The ass-whipping you'll get will be far less painful than the one Mitchell will give you the next day!
    Bianchi-Campagnolo
    Schwalbe failing carcass syndrome, Kerry.
    I might have used the wrong term but then again howís your Norwegian?
    Oct 2005
    My answer is none of the above. I managed around 3000 km on Pro Ones, but half a dozen punctures in that, some of which didn't seal. Switched to Hutchinson Fusions and they punctured 3 times in the first 200 km. The last straw for me was taking the bike into my local bike shop to have a cable replaced on the spot, and when I got on to test, got a puncture riding a figure of 8 in the car park. Though I managed to even top that when lifting the bike over the step to get it outside, and just the weight of setting it down again was enough to blow out one of the existing "seals".
    I'm a lightish rider (65 kg), but in my experience, not only do tubeless puncture more often (and a LOT more often), when they do seal, those seals won't hold longer term. I get it for mountain bikes, where the pressures are a lot lower, but I feel like if you're running anything more than 50 - 60 psi, they're not reliable, at least on the back wheel - though I was puncturing fronts as well.
    Whole experience was disastrous for me.
    Jun 2017
    Quote Originally Posted by upstateSC-rider View Post
    Thx for the input. I checked out the fusions and they are half the price of the GP5's, how many miles have you got out of the hutchinsons?
    Jun 2017
    Quote Originally Posted by bing181 View Post
    Thx for the input. I run into a lot of small wires on the road (steel belts from car tires?), my typical rides I get wires stuck in the tire and end up changing a tube, in fact I don't remember the last ride I had that I didn't replace a tube. My last ride before winter I ended up flatting my backup tube also and ended up calling my daughter for a ride. So I'm going to give tubeless a try and hope that it works better for me.
    Aug 2004
    Quote Originally Posted by davesupra View Post
    Had 1600 miles before I put her up for winter zwifting, starting to square off but nothing significant. Unlike the gp4k's, reports say the 5k's run truer to size so I may go to a monster-truck size of 28mm when I do switch.
    Sent from my ONEPLUS A5010 using Tapatalk
    Jun 2017
    I brought my wheels in (bontrager) to have them checked out before the season starts here, and the trek dealership had these rubbery-plastic rim strips that are made to be run tubeless. Has anyone else tried these? I picked them up and will give them a shot instead of taping the rims with the stans tape. I got them mounted and they are pretty slick, hopefully they work as well as they look.
    Reputation: GlobalGuy's Avatar
    Jun 2015
    I remember the early eighties where if you just looked sternly at your road bike the tires went flat.
    Jun 2018
    Keep us informed on the Bontragers. I'm interested in getting a set of Aeolus Pro 3Vs.
    Jun 2018
    Small wires on the road
    Thx for the input. I run into a lot of small wires on the road (steel belts from car tires?), So I'm going to give tubeless a try and hope that it works better for me.
    My 2 flats this year has been with those small wires on the road, on my tire with tubes. I also found 2 of these small wires on my tubeless tire. Pulled them out and sealant sealed up nicely.
    Jun 2018
    Which sealant are you running?
    What rim are you running?
    I'm a heavier rider (80kg) and I usually inflate to 85psi (and let it go low until 55psi). I have managed 6700km on Schwalbe Pro One 28c. All punctures sealed without my knowledge and I used a half-half mixture of Orange Seal and Orange Seal Endurance. This on a hooked rim (HED Belgium+).
    Jun 2017
    Quote Originally Posted by Fr0hickey View Post
    Mine are an aluminum wheel, I don't remember which model off of the top of my head.
    I've had good luck with the 25c Hutchinson Fusion 5 all season on I9 wheels ( spec'd w/HED belgium rims IIRC, Blue tape). The grip and wear are really good. Rode Hell of Hunterton using them and no problems with pavement or gravel.
    I tried Bontrager TLR tires but was unhappy with durability and grip in wet. The 23c Bontragers I used have been discontinued, and I assume the new ones are better.
    I tried the Bontrager rim strip on some Pacenti rims but it was more hassle than wrapping with tape and very sensitive to getting damaged during tire installation.
    I have my Bontrager cross wheels (Aluminum rims) set up tubeless with Vittoria tires and two layers of tape. Works great
    Sep 2011
    my experience has been similar as yours but to a lesser extent. One thing is for sure, it's almost never possible to get close to the full life of a tubeless tire (as tubeless). Once a tubeless tire has started to wear down past its midlife point, then old seals may break, or it's harder to seal new holes. Then you'll end up putting in a tube if you want to continue using the tire to the end of its life. This increases cost of use.
    Sep 2011
    do you carry a potato in your pocket in case you meet a Swede??
    Bianchi-Campagnolo
    Nonono. Iím quite friendly to Swedes as well.
    Jun 2018
    My experience is very different from yours. I've only replaced my rear tire after 4200miles, and not once did I get a flat that I noticed. I wore out the rear tire to the point that it was squared-off. The question though, is if this worn tubeless tire is still ok to ride? Maybe for short rides around town with no descents and good weather. But I certainly would not want to keep riding on a worn tubeless (or tubed) tire on long rides.
    Jun 2017
    I finally got around to installing my Schwalbe Pro one tires on the Bontrager wheels with the Bontrager rim strips. These rim strips are officially the spawn of satan. They are too thick in the middle of the rim where the spoke nipples are, which doesn't allow the tire to drop far enough into that area, the result is that you can't get the last ~10" of tire on the rim. After 45 minutes of struggle and bending the end of my park tool tire iron, I was finally able to get one side of the tire on. Once that one side was on, I was unable to spin the tire on the rim, because it was tight against the rim strip. I worked on getting the second side of the tire on, but quickly gave up. My next challenge was to get the one side of the tire back off of the rim. 20 minutes later and much swearing I finally got it back off.
    I removed the bontager rim strip and then put the tire back on the bare rim, it was a bit of work but no big deal. So, to make a short story long, I'll pick up some Stans tape and tape the wheel, as there is no way these rim strips are going to work.
    Jun 2017
    A quick follow up on this tubeless ordeal. lol So I brought my front wheel (which still has the bontrager tubeless rim strip) to the Trek dealer, I told them that there was no way to get the tire on with these strips. The mechanic acknowledged that they were difficult but that it shouldn't be too bad. ha. I told them that if they can get the tire on, to go for it. It took two mechanics and two broken tire levers before they were finally able to get the tire on. If I get a flat out on the road I will be screwed as there is no way I'll be able to get the tire back off. They offered to put a new rim strip on my rear wheel, but I declined. They were out of stans tape, so I brought the rear wheel in to a different shop and had it taped. I installed the rear tire, and got it aired up and sealded no problem. I went out on a ~30 mile ride with the new setup and it's nice, I think I need to tweak my air pressure a bit, but overall I think the ride was slightly better. I dropped almost exactly 1/2 lb off of the bike, I'm not sure how much of the weight difference was due to the different wheels and how much was due to the lack of inner tubes. The weight difference was very noticeable when accelerating.
    changingleaf
    Aug 2009
    Removing the rim strips also drops weight.
    Aug 2011
    The tubeless road tire selection is still not that good and still too much variation in quality control in my experience.
    For those new or considering tubeless here are some key points:
    Most TL tires are friggin hard to mount.
    Small punctures and even slices usually get you home especially if you keep riding. Stopping especially with puncture in up position might still leak. Slices even when sealant stops leak usually get worse so need to boot or give it the boot.
    You can carry tube and put one in if puncture doesnít seal but doing this on road can be frustrating or impossible for some rider.
    Taping rim properly is very important to success. No wrinkles, the right width and even coverage is hard for first timers to get but you get better every time.
    Back to original question Iíve had good luck and bad luck with Vitoria Corsa graphene 700x25 TL. One of the lightest fastest and not that difficult (this is relative tho) to mount. Iíve had one that lasted as long as any Michelin Pro Endurance or Conti GP 5000. Still running one on front that hardly ever loses air and I got a lot of miles on it. One tire got slice that sealant plugged but even with boot it never held air. One tire developed bubble in 2 different spots not on sidewall but contact surface with road. One bubble blew out and casing exposed but I was able to ride home. Not fixable so that got the boot too.
    These tires are fast and light for my riding which is smooth good to excellent asphalt and hardly any rough spots. Iím 185lbs.
  1. Replies: 6
    Last Post: 04-20-2014, 03:00 PM
  2. Replies: 21
    Last Post: 09-18-2012, 01:23 PM
  3. Anyone using tubeless on non-tubeless rims (Stan's)
    By Tahoe Gator in forum General Cycling Discussion
    Last Post: 05-02-2011, 06:32 PM
  4. Tubeless with non-tubeless tires
    By slow29er in forum Wheels and Tires
    Last Post: 02-16-2010, 06:00 PM
  5. Replies: 8
    Last Post: 11-18-2004, 06:32 AM
