Tubeless tires are driving me crazy!!!
Results 1 to 19 of 19
    Jul 2012
    I am relatively new to tubeless tires and liking them a lot. I purchased some Mavic Kysium Pro Carbon UST wheels with 28mm Yksion tires which are starting to wear out. I like the Yksion tires, but I wanted to explore the use of different tires.
    I had read that certain tires are more difficult to mount than others. Considering that UST was supposed to be a standard, I though most tires would fit this rim well.
    My two choices would be Schwalbe Pro 1 TLE and Continental 5000 TL. I really wanted the Continental becuase of decreased rolling resistance. I contacted both companies. Schwalbe responded first stating that their tires follow UST protocols and would fit fine and mount easily, Continental responded via a telephone call. Very impressive! Unfortunately, they told me it is designed for wheels of this design, but will not likely fit without significant difficulty, if at all.
    How is it that two companies can make a tire that fit so differently? I am baffled. There must be standards that need to be adhered to. Looking for more understanding.
    Thanks
    Steve
    Lynskey R300 disc SRAM 1x
    Lynskey titaniium seatpost
    Speedplay ultralight action pedals
    SMP Drakon saddle
    Redshift shock absorption stem
    Mavic Pro Carbon wheels
    Man I love this bike....
    Look 566 Rival (Still here but on my trainer)
    Look 765 up for sale (still a great bike!)
    'brifter' is f'ing stupid
    You have just discovered the difference between 'theoretically' and 'realistically'.
    #promechaniclife
    Adorable Furry Hombre
    Reputation: Marc's Avatar
    Jan 2005
    The GP5Ks are renowned for being bastards to get on, on basically all rims
    Reputation: velodog's Avatar
    Sep 2007
    You maybe coulda walked there.
    Too old to ride plastic
    Nov 2002
    You might want to check the "Tubeless Tire Experiences" thread on the Weight Weenies forum. The OP of that thread says Hutchinson Fusion tires work well with Mavic UST rims. I guess that makes sense, since Hutchinson makes Mavic's tires. I've got UST rims as well but have only used the Yksilon tires on them and am pretty satisfied with them.
    Dec 2006
    I could be wrong, but some rim manufacturers use proprietary tubeless rim technology. Compatible tire manufacturers may have TO PAY to use the technology to make compatible tires. In some cases, it's a collaboration, in an effort to promote both brands. And some tire/rim manufacturers will just try to make a product that is compatible with all brands.
    That's likely the reason your Mavic rim/Mavic tire combination worked so well for you.
    Consider that when trying to find compatible tires.
    tlg
    tlg is offline
    Reputation: tlg's Avatar
    May 2011
    Quote Originally Posted by 1Lieutenant View Post
    There are numerous standards. Which is the problem.
    Continental GP5000's are made to the new ISO ETRTO standard. Which hopefully will be the dominant standard going forward.
    Coincidentally, here's an article about Conti 5000 TL on Mavic Kysirium Elite UST wheels
    https://intheknowcycling.com/fitting...ss-road-tires/
    FWIW, I use GP5000's and they're great. I can easily get them on several wheels with a single tire lever when new. And on/off by hand once they're stretchered a bit. (but I don't have any UST wheels)
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    Bingo!
    Just one more reason I'm not sold on tubeless.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
    Russian Troll Farmer
    Sep 2016
    You obviously have never heard the 1st rule of bike tires: Continental tires ALWAYS fit tight. Doesn't matter on the type. Road clinchers, mountain bike, even tubulars; Contis are always a b!tch to mount.
    "L'enfer, c'est les autres"
    Sep 2011
    and what's wrong with just sticking with Yksion tires?? They are good tires. One of the major benefits of Mavic UST wheels is that they work GREAT with Mavic UST tires, so why you want to stray away from this benfit?
    On a sidenote (not meant to direct toward the OP specifically), all this obsession with rolling resistance is getting to the ridiculous level in the ranks of weekend warriors. Let's say you're rolling at 20 mph, the effort it takes to overcome wind resistance caused by your body/bike trumps the 1-2 watts rolling resistance difference between tire brands. Simply just tighten up your helmet-strap alone saves you 3-5 watts at 20 mph
    Nov 2002
    Even worse is the obsession with fictional differences between chain lubes.
    Banned Sock Puppet
    May 2014
    And neither of these makes much difference in the real world of cycling outside of a tight race.
    "With
    -- DCGriz, RBR.
    Banned Sock Puppet
    May 2014
    even worse is the obsession with fictional differences between chain lubes.
    Spike......5....4.....3....2.....1
    "With
    -- DCGriz, RBR.
    Jul 2012
    I have no problem with the Yksion tires except the price. The Continental, Schwalbe, Mavic are expensive, but the Continental and Schwalbe go on sale periodically. I have never found the Mavic UST on sale.
    Steve
    SMP Drakon saddle
    Nov 2002
    I like the Rubio Pro's. I may try the tubeless version next.
    Reputation: stevesbike's Avatar
    Jun 2002
    Bit late but in case OP is still looking around - I've tried virtually all brands of tubeless road, gravel, etc. For road, I find that Hutchinson Fusion (the new versions with 11storm) are the best combination of ease of fit, performance, weight, and longevity (the performance model for that). As an added bonus, you can find them for good prices at places like sigma sport, which take about 4 days to arrive from UK. I opt for tubeless ready - the Conti tubeless is OK, though I've never quite understood tubeless over tubeless ready - they weigh more and the whole point of tubeless is to use sealant. For that, my recommendation would be orange seal.
    Jul 2012
    Thanks! Will look into it
    Steve
    SMP Drakon saddle
    Reputation: Srode's Avatar
    Aug 2012
    Schwalbe Pro one Addix (Their new version of pro one) is supposed to be easier to mount and remove than the previous version. I've been able to mount the previous version without levers and they come off fine with a little help from a tire lever once you get them off the ledge and into the center channel of the rim. How easy they are to install and remove is obviously going to depend on the depth of the channel on your rims. I wouldn't consider Conti 5000's TL because of the horror stories.
    Gravel Rocks
    Trek Domane
    Niner RLT9 (Gravel Bike)
    Niner RLT9 RDO
    BH G7 Disc
    Trek Crockett
    Apr 2011
    I remember a parody song of John Mellencamp's I Need a Lover sung by kids back in my school days that goes something like "I need a rubber that won't drive me crazy..."
  1. My dog is driving me crazy
    By ToF in forum The Lounge
    Last Post: 12-19-2008, 02:31 PM
  2. Lame commercials are driving me crazy
    By innergel in forum The Lounge
    Last Post: 04-27-2007, 03:53 PM
  3. lame greeting cards are driving me crazy
    By Hollywood in forum The Lounge
    Last Post: 04-27-2007, 02:11 PM
  4. Clicking noise driving me crazy
    By gnauss in forum Components, Wrenching
    Last Post: 08-30-2006, 05:01 AM
  5. The noise is driving me crazy
    Last Post: 09-12-2005, 08:27 PM
