Tubeless valve stem
Results 1 to 5 of 5
    Apr 2011
    Tubeless valve stem
    How much do tighten them when you first install them?
    Thanks
    Brian
    'brifter' is a lame word.
    Tight enough so there isn't any air leaking past them, not so tight you can't get them undone. If you're looking for some kind of number to put on it, forget it...doesn't exist.
    I work for some bike racers
    and a bunch of skateboards
    Apr 2011
    Thanks, finger tight it is.
    Sep 2010
    Are all tubeless valves the same, that is, are there enough differences in road tubeless valves to make it worth using one kind rather than another?
    Not the same. You want to use the one that was supplied w/ your rim. If that isn't possible you want one that fits properly, meaning one that probably looks very similar to the original.
  1. Best road tubeless valve stem for Pacenti SL23
    By bobonker in forum Wheels and Tires
    Last Post: 08-16-2013, 11:34 PM
  2. Can I install a VALVE CORE on my VALVE EXTENDER?
    By B05 in forum Components, Wrenching
    Last Post: 08-14-2012, 10:09 AM
  3. Stan's tubeless valve stem problem.
    By ddimick in forum Wheels and Tires
    Last Post: 11-10-2011, 04:03 PM
  4. Long Valve OR valve extender?
    By AaronMaechand in forum Wheels and Tires
    Last Post: 05-11-2010, 08:51 AM
  5. Valve Extenders or Long Valve Tubes ?
    By Macilvennon in forum Wheels and Tires
    Last Post: 10-10-2009, 07:36 AM
