Tubes and tires on 1990s Raleigh road bike
Results 1 to 3 of 3
    Mar 2014
    I purchased a Raleigh road bike off craiglists. It's in great condition and was most likely not ridden a lot because it still has its original tires. One of them has a slow leak and id like to replace although the tire is so old and corroded I can't read the size on it. I've heard from bike knowledgable friends that the size/air pressure on these older bikes might be a little different. Does anyone know what that might be? I'm not sure the exact year of the bike, although around mid 90s.
    A wheelist
    Probably 27 x 1-1/4". It could be 700c size (the modern road bike diameter). If you see a size on the tire side wall, can you give us a wheel diameter? Measure it in any units you want and we'll just compare to 700c and I think I have a 27" wheel around here somewhere.
    Reputation: JCavilia's Avatar
    Sep 2005
    Yeah, what he said. Look all over both tires and both rims and see if you can find either a "27" or "700." It's one or the other.
    It's tricky to figure it out by measurement, since the difference in diameter is so small (8mm) so you'd have to do a really careful measurement.
    That time period is about when road bikes in the U.S. were in transition, but if it's really as late as mid-90's I think it's likely to be the newer 700c.
    "None of us knows for sure what's out there; that's why we keep looking. Keep your faith; travel hopefully. The universe will surprise you, constantly." The 13th Doctor.
  1. Where can i buy 14 inch tires /tubes for a folding bike?
    By Har in forum General Cycling Discussion
    Last Post: 04-03-2013, 03:29 PM
  2. Raleigh road bike for $20???
    By rglass in forum Bikes, Frames and Forks
    Last Post: 04-04-2010, 10:07 AM
  3. Allez Specialized road bike - 1990s, good buy?
    By jasichel in forum Beginner's Corner
    Last Post: 11-29-2009, 01:43 AM
  4. Road tires/tubes - frequent flats?
    By E 12 in forum General Cycling Discussion
    Last Post: 08-15-2008, 08:59 AM
  5. Raleigh Team Road Bike
    By ambishn in forum Bikes, Frames and Forks
    Last Post: 02-20-2005, 03:54 AM
