Tubes or Tubless, 28 or 32?
Results 1 to 19 of 19
    Jun 2010
    Hey Guys,
    Got a new bike recently that can accomodate wider tires (2019 Spec Roubaix Comp Di2). I've gotten enough miles to where it's time to replace the tires. Really just the rear is worn and I could rotate front to back but I am just going to get the set. It's currently got the stock specialized 28's with tubes, which were nice enough. Coming from 25's tubeless (GP5000's) on my last bike they seemed good. I am leaning towards the conti's again because I've always like the GP4000's and then the 5000's after them. The real questions for me are if 32's are worth running over 28's and if tubeless is worth the mounting hassle (especially if you flat on a ride) over tubes? Also, what are recommended pressures at these widths? I'm 240+ depending on clothing options and pre-ride hydration and meal. I previously ran 105psi on 23's and 90-95 on 25's.
    Thanks!
    Jul 2006
    At your size 32 mm will make a notable difference. 32-33 mm is where tubeless starts to work well and become much more reliable.
    Road Warrior
    Reputation: n2deep's Avatar
    Mar 2014
    I like the idea of tubeless however I believe they are impractical and a real pain in the kiester for true road bikes.. Changing tubes is just too easy.
    Reputation: Rogus's Avatar
    Nov 2010
    A road bike tubeless question always creates a long debate between cons/benefits.
    I weighed 200-225 lbs. (Currently 185.) Have now ridden 32 tubeless tires for a couple years. Work well for me, but have never had a flat in the 19,000+ miles I've been using them. So, I haven't had to deal with the mess regarding a flat on a ride that many cite as a major negative to tubeless.
    'brifter' is f'ing stupid
    Not worth it. I went back to tubes 7 years ago and I've had one flat since. No where near the advantages you get w/ mtb tubeless. I'm 100% for it on the mtb, 100% against it on the road bike.
    #promechaniclife
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    I agree that tubeless isn't worth it. I use tubes and I get less than one flat per year.
    At your weight, I say definitely go with 30 or 32mm tires. I use Vittoria Rubino Pros which are a good compromise between comfort and puncture resistance. They have these up to 30mm:
    https://www.vittoria.com/us/rubino-p...ance-race.html
    "With
    -- DCGriz, RBR.
    Reputation: krisdrum's Avatar
    Oct 2007
    Might want to take a look at your tubes choice as well. I have found the latex tubes to be a better choice for their increased flexibility. Run them in my 28 road tires and I've run them in the low 30s with 32s and 34s on cross courses and had no issues. Yes, they are pricey, but so far I've found them to be worth it.
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by krisdrum View Post
    They also lose air quicker than butyl tubes. Just saying.
    "With
    -- DCGriz, RBR.
    Oct 2007
    True. So it is an extra minute? 2? pre-ride to check inflation and adjust as needed. I feel like most of us are checking our tires pre-ride regardless. Minor inconvenience in my experience. YMMV.
    MDM
    MDM is offline
    Jun 2020
    What about for gravel/cyclocross? 50-50?
    Reputation: Notvintage's Avatar
    May 2013
    you should check pressure before each ride, and the ride quality of latex is worth the extra 30 seconds to top up.
    Quote Originally Posted by MDM View Post
    For actual CX racing? Tubulars. I'm old fashioned so I'll say tubulars 90, tubeless 10. gravel, I'd go tubeless. Gravel tires are nearly the size of XC mtb tires, so tubeless works for me in that case. CX tires are relatively narrow and cornering speed is your friend, so tubulars can't be beat.
    #promechaniclife
    Banned Sock Puppet
    May 2014
    Quote Originally Posted by Notvintage View Post
    I'm lazy and only check pressure if it's been 4 or 5 days since I last pumped up. In between, I check by giving the tires a squeeze.
    "With
    -- DCGriz, RBR.
    Reputation: velodog's Avatar
    Sep 2007
    Too old to ride plastic
    Banned Sock Puppet
    May 2014
    Lots of good info here which just confirms that I have no desire to try tubeless.
    *Harder to mount
    *Stiffer sidewalls negate any comfort advantages of being able to run less pressure.
    I can see the merits of running tubeless on mountain tires, but not road tires. That being said, unless you are doing the really rough stuff, mountain tire flats are pretty rare.
    From the article:
    What are the advantages of road tubeless?
    There arenít any real advantages. Tubeless tires donít pinch flat, but that has become almost a non-issue on the road as riders have moved to wider tires.
    Why are tubeless tires slower than tires with tubes?
    Tubeless-compatible tires have liquid sealant inside, which increases their resistance more than the thin membrane of a lightweight tube.
    Tubeless tires that donít require sealant have more rubber on the sidewalls to make them 100% airtight. This makes them slower than more supple tires that donít have thick, airtight sidewalls.
    Is the tire pressure different when I run tubeless vs. with tubes?
    Without a tube, the tire has a little less internal stiffness, so to get the same feel, youíll have to run slightly higher pressures. In real life, this effect is too small to make a noticeable difference. Mostly, you can run lower pressures with tubeless tires because you donít have to worry about pinch flats. Donít go overboard, though: If you bottom out too hard, you can still destroy the tire and the rim. And if you run your tires at pressures that are too low, the sidewalls will start to break down prematurely.
    "With
    -- DCGriz, RBR.
    As for the whole "able to run lower pressure thing"........IMO the solution to that is to just use a tire that's appropriate size and/or learn to not hit railroad tracks with all weight on the saddle.
    I can use 60 PSI on 25mm tires and not really worry about pinch flats. I'm only 145 pounds but if I put on a 100 pounds my answer would be bigger tires not tubeless. Not for everyone but should be considered as an option IMO>
    If tubeless helps avoid a lot of small shard type of flats that would be cool for someone who get a lot of those. I don't get it for avoiding pinch flats and smoothing out the ride though.
    Surprised people tend not to put the latex tube option out there too. Seems to me there are little smoother and while certainly not immune to flats including pinch flats they are more resistant.
    Banned Sock Puppet
    May 2014
    Bingo!
    Are latex tubes really more puncture resistant? I thought just the opposite.
    "With
    -- DCGriz, RBR.
    Agree 100% w/ your post.
    #promechaniclife
    yes, they are.
  1. Steel Bike Wheel Build - 24/28 or classic 32/32?
    By zucchiniboy in forum Wheels and Tires
    Last Post: 02-26-2016, 02:34 PM
  2. Tubes, Tubes, Tubes, there is a difference
    By Mr645 in forum Wheels and Tires
    Last Post: 10-06-2014, 08:26 PM
  3. Tubes or Tubless...Again
    By teambcw in forum Wheels and Tires
    Last Post: 07-03-2013, 06:54 AM
  4. Spare cassette for hilly rides 11-32 or 12-32?
    By Spursrider in forum Components, Wrenching
    Last Post: 05-24-2011, 06:29 PM
  5. 24/28 or 28/32 for DA/HED Belgium C2 Build
    By grande in forum Wheels and Tires
    Last Post: 04-03-2011, 08:47 AM
