What size tube should I go with?
Results 1 to 9 of 9
    Jul 2012
    I have 25mm wide wheels with the Continental 4kIIs tires (700x25). When inflated the Continental tires are right at about 28mm wide. So, should I go with the 18-25mm tube or the 25-32 tube and why?
    Thanks...
    'brifter' is a lame word.
    I'd go w/ the smaller tubes because they're easier to stuff into the tire...and a couple/3mm just don't matter.
    I work for some bike racers
    and a bunch of skateboards
    Dec 2006
    The smaller sized tube can be considered a "poor man's lightweight tube". Either size you mention will fit; the smaller tube will save some grams.
    Jul 2012
    Sounds good. I will order the smaller size tubes.
    Thanks...
    Russian Troll Farmer
    Sep 2016
    Oh good lord, not THIS again...
    "L'enfer, c'est les autres"
    Jul 2012
    What?
    Jul 2012
    What?
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Go with the smaller tube. It's easier to put in and there is less chance of pinching it while mounting.
    Jul 2012
    Sounds good Lombard. Thanks
  1. Replies: 3
    Last Post: 01-17-2014, 03:33 AM
  2. What size mtb top tube should I have? And what size stem?
    By barbedwire in forum General Cycling Discussion
    Last Post: 06-16-2008, 08:04 PM
  3. Tube size and Tire size??? 700x23 tires
    By tyjacks in forum Beginner's Corner
    Last Post: 06-19-2007, 05:30 AM
  4. tire/tube size leeway & stem size?...
    By Paul LI in forum Beginner's Corner
    Last Post: 05-21-2006, 04:39 PM
  5. Silly tube question... 23c tube in a 25c tire?
    By asterisk in forum Components, Wrenching
    Last Post: 07-29-2004, 04:35 AM
