Wheel build
Results 1 to 11 of 11
Thread: Wheel build
    Feb 2013
    Wheel build
    Got some bad news from my LBS last night that my rear wheel(Dura Ace 7800) is cracked. The wheel only has around 7000 miles on it. Would like to re-use the hub on it to build another wheel. Looking for suggestions, Wheel, spokes. My weight is around 190 and ride on roads that are normally in good shape and I do a fair amount of climbing.
    Reputation: VinPaysDoc's Avatar
    May 2005
    Is it a Dura-Ace 7800 hub? How many spoke holes? Do you have a picture?
    Feb 2013
    It is a 7800 Dura Ace hub and I believe the spoke count is 20, but I will verify with LBS as they have the wheel at the moment.
    May 2005
    Looks like 20 spokes, straight pull. 20 spokes on the rear for a 190 pound rider might be asking a bit much.
    Also, these look to be hubs that have the nipples at the hub rather than at the rim. Apparently, the rims do exist and you might be able to get your LBS to order a replacement for you. Of course, you may be looking to do this all over again in another 5K miles.....
    Reputation: GRAVELBIKE's Avatar
    Sep 2011
    What exactly cracked? The rim? The hub?
    I weigh 195#, and the lowest spoke-count that I run is 28h (rear).
    GRAVELBIKE.COM - ride everything
    Feb 2013
    Quote Originally Posted by GRAVELBIKE View Post
    The rim cracked, the hub is fine. I also have an Ultegra hub I could use which has a 32 hole spoke count. Just need some ideas on Rim and Spokes.
    May 2005
    Go with the Ultegra Hub if it's in good condition. Here's a link to reviews of some of the 2013 rim options:
    2013 Rim Roundup - Fair Wheel Bikes
    What is most important to you for your wheel choice? Durability? Ride comfort? Aero? Price?
    Feb 2013
    Quote Originally Posted by VinPaysDoc View Post
    Great info, thanks for the link. Durability, weight, price, in that order.
    Sep 2011
    Quote Originally Posted by gpa357 View Post
    Rims: H+Son Archetype, Pacenti SL23, Velocity A23
    Spokes: DT, Sapim, Wheelsmith (depending on budget)
    Feb 2013
    Thanks for the advice guy's. I ended up having my LBS order me a Velocity A-23 with DT 2.0 spokes. He laced it up to my Ultegra Hub(32 spoke) for $147.00 total cost.
    May 2005
    That should serve you well.
  1. Replies: 38
    Last Post: 01-30-2012, 05:12 PM
  2. Next wheel build
    By yellowjeep in forum Wheels and Tires
    Last Post: 01-29-2012, 07:13 PM
  3. Need help for wheel build
    By Kristatos in forum Wheels and Tires
    Last Post: 11-10-2008, 06:23 AM
  4. build a wheel
    By yetisurly in forum Commuting, Touring and Ride Reports
    Last Post: 08-25-2008, 11:41 PM
  5. Wheel build ??
    By Kram in forum Cyclocross
    Last Post: 04-11-2006, 06:23 AM
