Wheel build, need some tips :)
Results 1 to 5 of 5
    Jan 2011
    Hey Guys,
    i plan to build my own wheelset, carbon clincher 55 mm with Sapim Xray spokes.
    when it comes to the hubs, iam not sure!
    1) DT SWISS 240S (20 Spokes front and 20 or 24 rear)
    2) Tune Mig70 (18 spokes front Mig170 20 Spokes rear)
    What you guys would say concerning the strength of both setups?
    We have an Triathlon Magazin here in Germany which tested a lot of wheels, and the most had less than 18 spokes in front and 20 back, and the recomendation concerning weight was 110 kg riderweight.
    So would my second setup be strong enough to handle this weight? 100 kg - 110 kg?
    'brifter' is f'ing stupid
    It depends on how hard you are on wheels. If you've had problems in the past w/ wheels going out of true I'd recommend as many spokes as possible. If you don't have wheel problems you should be fine w/ either. 110kg is heavy.
    #promechaniclife
    Jan 2011
    Cool
    no, my weight is about 84 kg and my Bike is about 7,01 kg. Iam using the Spinergy PBO Stealth in past ive used also the Mavic Ksyrium elite and never had any problems but i wanna build this with a kind of space concerning weight.
    Rub it............
    Reputation: frdfandc's Avatar
    Nov 2007
    I'd go 28 spoke count front and rear. Stronger than 20/24 but lighter than 32/32. Hell, I built up a set of Stan's No Tubes Crests on Sram XO hubs with DT Supercomps 32 spoke count. Came in just a hair over 1500 grams for the set.
    If you get the right rim and hub combo, it can be strong and light.
    You can't fix stupid.
    Quote Originally Posted by JoeDaddio
    Banned Sock Puppet
    Reputation: Lombard's Avatar
    May 2014
    At 84kg, I would go with no less than 24 spokes front, 28 spokes rear. If you really feel compelled to go with fewer spokes, you could do 20 in front, but I wouldn't do any less than 28 rear.
    Personally, I don't like DT Swiss hubs for two reasons - they have an aluminum freehub and they are noisy as heck. Aluminum freehubs are prone to cassette gouging. If/when this happens, shifting will be poor and you will be uttering every curse word in existence when you try to remove the cassette from the freehub. I would go with Shimano Dura-Ace or White Industries T11 instead.
    "If someone needs 200 rolls of toilet paper for a 14-day quarantine, they probably should have made a doctor's appointment way before the COVID-19 outbreak." -- Unknown
    "With
    -- DCGriz, RBR.
  1. Need some opinions on this wheel build
    By Gharp23 in forum Wheels and Tires
    Last Post: 04-30-2013, 01:26 PM
  2. help, I need some rabbit hunting tips.
    By bimini in forum The Lounge
    Last Post: 04-20-2010, 01:11 PM
  3. Replies: 26
    Last Post: 06-06-2009, 10:32 AM
  4. Need some cleaning tips
    By Tangelo in forum Components, Wrenching
    Last Post: 07-15-2007, 06:03 PM
  5. Century Coming up and need some tips.
    By ewillia7 in forum Beginner's Corner
    Last Post: 08-28-2005, 07:19 PM
