Where to find 700c, double wall, presta wheel with 130mm frehub?
Results 1 to 8 of 8
    cityrider
    Mar 2011
    Can't find replacement for Sun CR-18/Shimano Deore frehub wheel on my 1996 steel Trek hybrid with 7 speed cassette. Original spacing 126mm, added spacer to accommodate 130mm.
    Looking for tough, durable wheel to run 32mm tires on NYC commute.
    Where can I find wheel with below criteria?
    700c
    double wall
    presta
    frehub
    130mm
    'brifter' is a lame word.
    Seriously? Any bike shop can order a wheel like that, there are many available. I'm sure you can order one directly. I know for a fact that Bontrager have 8-9 that fit your description.
    I work for some bike racers
    and a bunch of skateboards
    [REDACTED]
    Reputation: Lombard's Avatar
    May 2014
    Quote Originally Posted by cityrider View Post
    700c
    double wall
    presta
    frehub
    130mm
    For a NYC commute, you want something as bombproof as possible. 130mm is now the standard road size. You won't be able to use a newer Deore hub as that is a mountain bike size of 135mm.
    Prowheelbuilder can customize for any build you want:
    https://www.prowheelbuilder.com/cw/i...hp?step=review
    A good commuter build for you would have as many spokes as possible. 36 spokes front and rear would make a good commuter build. So you could get:
    Rims: DT SWISS TK 540 700C (36 hole)
    Hubs: SHIMANO ULTEGRA HB6800 (36 hole)
    Spokes: DT SWISS COMPETITION 14/15/14
    Lacing pattern: 3 cross or 4 cross
    Nipples: DT SWISS 14G 12MM BRASS
    Total Price: $518.16
    Total Weight: 2,079.36 grams
    Note:
    I entered Ultegra hubs as they aren't much more expensive than 105 hubs. If you want to squeeze the buffalo, you could get 105 hubs.
    They recommend DT Champion spokes which are 14g straight gauge. I put in DT Competition butted 14/15/14 gauge instead. While it may seem counter intuitive, butted spokes are actually stronger. The weakest part of a spoke is at the nipple and the j-bend. By making the spoke thinner in the center, it will flex more here and less at the vulnerable nipple and j-bend ends, thereby extending the life of the spoke. I have honestly never heard of a spoke breaking in the center.
    Brass nipples are a must. Do NOT use alloy nipples for a commuter build.
    Hope this helps.
    Russian Troll Farmer
    Sep 2016
    Man, if you can't find a cheap hybrid wheel over at www.the-bikeshop.com, then you must be looking for something unobtainable.
    https://thebikeshopstore.com/categor...ls/wheels/700c
    "L'enfer, c'est les autres"
    cityrider
    Mar 2011
    Thanks. Correction, the rear dropout width is 135mm. Found 1996 Trek spec sheet.
    [REDACTED]
    May 2014
    OK, that's a standard rim brake mountain bike hub size.
    Sep 2016
    So, then, you need a "29'er" wheel....
    But, all you need to make a 130mm spread fit is a .100" thick washer on each side..
    [REDACTED]
    May 2014
    No, he needs a new/old stock hybrid or touring wheel. Just about all "29er" wheels are disc brake wheels.
    I don't normally recommend Mavic. However, the A719 is one of their better efforts. These are paired with Shimano XT hubs:
    https://www.ebay.com/itm/Mavic-A719-...-/183832780978
  1. Replies: 24
    Last Post: 02-15-2019, 07:28 AM
  2. Replies: 23
    Last Post: 05-02-2012, 11:58 AM
  3. Looking for SS CX 700c 130mm hub or wheel
    By steveyo in forum Cyclocross
    Last Post: 03-17-2011, 07:16 AM
  4. 700c rear wheel with 26 inch front wheel?
    By everst in forum General Cycling Discussion
    Last Post: 07-23-2008, 04:20 PM
  5. trek 5200 presta or XL presta
    By vkhalsa in forum Components, Wrenching
    Last Post: 07-12-2004, 07:44 PM
