Why not 28mm tires?
Page 1 of 6 123 ... LastLast
Results 1 to 25 of 138
    Reputation: Rogus's Avatar
    Nov 2010
    Why not 28mm tires?
    I realize not everybody agrees that 25mm tires are faster/better than 23mm, but IF YOU DO, then why aren't 28mm tires considered even better? Certainly there's a point where weight and aerodynamic drag becomes an issues but where is that point?
    Steaming piles of opinion
    Reputation: danl1's Avatar
    Quote Originally Posted by Rogus View Post
    An awful lot of bikes won't take 28's, so there's that.
    And honestly, saying one or the other is 'better' is right up against silly. It depends on surface conditions, rider weight, which particular tires...
    but in the most general sense, I'll say 28's are near the 'too big' side of things. Unless you are rather heavy, and riding on crappy dirt and gravel roads, when they're not nearly big enough.
    A good habit is as hard to break as a bad one..
    Aug 2011
    They are "better" period.
    I ride a Roubaix and a kg 381 and 28's fit nicely. Only on the rear of a 381 though. The point where aerodynamics matter is when you're a pro racing for a WC. Otherwise it doesn't matter. Anyone who says it matters; their legs aren't strong enough.
    The ride is so much better than 23's it's not even funny.
    Feb 2002
    Availability
    While you can argue that 28mm tires should be more common, the reality is that most high-end tires are only made up to 25mm. When the current concept of 700c clinchers replacing tubulars hit the market in the early 1980s, the tires were super narrow. They have widened considerably since so the trend may continue. That would require a lot of bike manufacturers to offer frames and forks with more clearance.
    Apr 2010
    You also get that light bulb effect with a lot of the 19 mm rims out there. That severe "rounding" puts extra stress on the sidewall and increases the chance of pinch flats.
    If you have some of the newer 23 mm rims, then there is less effect. However, you still have to clear your fork and rear triangle
    I run 25 mm tires on 19 mm rims. That's about as much as I feel comfortable with on the light bulb effect
    It's a fire road.............
    I'm on a road bike..........
    They have enough in common to blast down it.
    Aug 2011
    Quote Originally Posted by ziscwg View Post
    Open Pro - rims - road & triathlon - Mavic
    FEATURES
    Maxtal
    SUP
    Traditional drilling
    UB Control
    CD
    Double Eyelet
    Low profile
    Clincher
    DIMENSIONS
    ETRTO compatible size: 622 x 15
    ETRTO compatible size: 571 x 15
    Recommended tyre widths: 19 to 28 mm
    Valve hole diameter: 6.5 mm
    Recommended nipple length: 12 mm
    Recommended rim tape: 622 x 16 x 0.6
    Recommended rim tape: 571 x 18 x 0.6
    As a note, people are running tyres wider than 28's on open pro's.
    Old and Fixed, Moderator
    Jan 2002
    I run Panaracer Ruffy Tuffy 28c tires... 120psi max....I run them at 110psi. My favorite tire....I'm using Open Pro/Dura Ace wheels
    If you don't want the extra weight for the flat protection, the Rolly Pollys are also a good tire
    Dave Hickey/ Fort Worth
    Carbon Fiber = Explode!
    Reputation: CleavesF's Avatar
    Dec 2007
    ^^^ running 35's on mine. Not a problem
    '09 Voodoo Wazoo
    '08 Pedal Force RS2
    '06 Raleigh Cadent 5.0
    '01 Trek 4300 MTB
    '93 Norco Nitro MTB Touring
    '88 Schwinn Prelude Fixie
    1 hour of running = 1 hour of wasted time when you could have been riding. - Alaska Mike
    Jul 2011
    Quote Originally Posted by CleavesF View Post
    I use old SUV tires. Passed this guy Lance on his skinny 23's. Wuss.
    Aug 2011
    Quote Originally Posted by NJBiker72 View Post
    Lance knows there are much more important factors in one's "preparation" than tires.
    Big is relative
    Reputation: bigbill's Avatar
    Feb 2005
    I like bigger tires but my custom won't take bigger than a fat 23 on the front and the Reynolds fork on my Peg won't take all 25's. My Gunnar Crosshairs with fenders that I use for commuting will fit 28's but it's tight on the front, especially if the tire picks up some mud. My MX Leader will run 28's. As far as rolling resistance and comfort, I did a ten hour double century on 25mm four seasons.
    Retired sailor
    Aug 2011
    Quote Originally Posted by bigbill View Post
    Congratulations! Very impressive!
    251 is offline
    Reputation: 251's Avatar
    Nov 2009
    Do you have the stock Gunnar fork on that Crosshairs? I've had up to a 38mm knobby on the front of my Crosshairs and have plenty of room left for fenders:
    Dave
    Blog / Strava
    Big is relative
    Feb 2005
    Quote Originally Posted by 251 View Post
    I have the stock steel fork. My Gunnar is set up for road commuting so I use SKS narrow fenders which limit my clearance. At one point, I had wider fenders with more clearance, but I found that I got more splatter and crosswind issues while using 28 mm tires. The closer I keep the fender to the tire, the better.
    Retired sailor
    waterproof*
    Reputation: Creakyknees's Avatar
    Sep 2003
    My racing bike won't fit 28's. My non-racing bike, I use 32's. They are just right - roll fine on pavement, can handle abuse on gravel / dirt / lite singletrack.
    Before I bought the current racing bike, I was using 28's on the other bike, and racing on them. Didn't seem to slow me down too much, I won one race and had plenty of placings.
    * not actually a Rock Star
    Yo no fui.
    Reputation: Pablo's Avatar
    Jul 2004
    Quote Originally Posted by dave hickey View Post
    i run panaracer ruffy tuffy 28c tires... 120psi max....i run them at 110psi. My favorite tire....i'm using open pro/dura ace wheels
    convert!
    "It is better to conquer yourself, than to win a thousand battles." -Dhammapada
    "Fact is only what you believe; fact and fiction work as a team." Jack Johnson
    "A true cyclist sometimes has to bite the dust before he can reach the stars. Laurent Fignon
    Slightly Opinionated
    Reputation: robdamanii's Avatar
    Feb 2006
    Quote Originally Posted by Chris-X View Post
    Leave it to you to throw doping into the whole mess....
    The big problem I see with 28mm tires is pinch flat resistance and clearing the frame. If you can manage those well enough, knock yourself out.
    Quote Originally Posted by bigrider View Post
    Teh Lounge- "Its not just for weirdos anymore. It is for those trying to escape the noobsauce questions."
    Quote Originally Posted by QuiQuaeQuod View Post
    Trolling the lounge is like noodling for piranha.
    The Daily Grind Cycling Journal & Tailwind Coaching
    Anphaque II
    Reputation: cda 455's Avatar
    Aug 2010
    For me, the smallest tire I should run is 700x28 for speed. For comfort and speed for me is 700x32. For comfort in commuting, etc. 700x38+.
    There's no way I would ride on 700x23 or 700x21. 700x25; Maybe.
    I'm in the 200lb+ crowd (Clydesdale).
    America's greatest threat: Congressional liberal Democrats
    Crimes Against Humanity: The History of The Democrat Party
    Reputation: tarwheel2's Avatar
    As others mentioned, 28 mm tires won't fit on most road frames and some won't handle 25s. There isn't much selection when it comes to light weight, foldable 28s but there are some good options such as the Ruffy Tuffys, Panaracer Pasela TGs, Continental GP 4 Seasons and Clements. I tried the Paselas and didn't like them because they seemed to have a lot of rolling resistance, but I love my Conti GP 4 Seasons. Fortunately I got my 4 Seasons before the recent Conti price hikes because they are very expensive right now. The other issue to consider is weight. Most 28s seem to have wire beads and much heavier than the foldable versions.
    Nov 2010
    Lots of helpful information in the replies. Thanks to all.
    Of course, those of you who've been around or searched already know, but I didn't realize that there were few 28mm choices in the supposedly better quality tires. I had heard that some frames wouldn't fit the larger tire, but now that I've decided I want to be able to use at least 25mm and preferably 28mm tires I will make sure to pay attention to that in my bike decision.
    @ziscwg--I had never heard of the "light bulb effect".
    @robdamanii--Are you saying 28mm tires would be more susceptible to pinch flats?
    @Chris-X--Thanks for the links.
    @tarwheel2--Thanks for pointing out that fold-able are lighter tires than wire beaded tires. Though I'm not sure if this means there are choices of the same brand and size tire between fold-able and wired. I will have to check.
    Apr 2010
    FEATURES
    Maxtal
    SUP
    UB Control
    CD
    Double Eyelet
    Low profile
    Clincher
    DIMENSIONS
    Sure, but 25 is MY limit I will go with. I'd love a 25 mm Road Tubeless rim right now. I would consider strapping a 23 mm RT rim on if I could find one that was 25-30 mm
    Jan 2008
    +1
    All else being equal, a fatter tire has less rolling resistance. But all else is not equal -- 25mm is the break point for most tire manufacturers, where they don't go any larger with their best/fastest casings.
    Various Continental models as well as Serfas Seca are available in 28mm, maybe bigger.
    Sizes are nominal anyway. Some 25mm Michelins are more like 27mm, while some 28mm Contis are more like 25mm.
    Go as big as you can. My Klein frame will take at least a 28mm. Some frames won't take bigger than 23mm. Why people buy them is beyond me.
    Note that I ride 23mm Michelin Carbons, as i've been getting them at a good price. The 25mm were a lot more the last time i bought.
    Virginia Bicycling Federation (www.vabike.org)
    bikeNewportBeach.org
    In Myrtle Beach? Connect with the Grand Strand Cyclists on Facebook.
    Feb 2006
    If the rim isn't wide enough to prevent the tire from "ballooning" it can pinch.
    Nov 2010
    Quote Originally Posted by robdamanii View Post
    I think someone else called this light bulbing.
    OK, so it's not solely because of it being a 28mm or larger tire, but becasue the tire width was too large for the rim. Makes sense. Is the opposite a problem? Where's the point where a tire is too narrow for a rim?
  1. Will 28mm tires fit on a compact
    By b712 in forum Moots
    Last Post: 10-11-2010, 06:59 PM
  2. White 28mm Tires
    By bikerneil in forum Look
    Last Post: 01-25-2010, 10:37 PM
  3. favorite 28mm tires?
    By teleguy57 in forum Wheels and Tires
    Last Post: 11-20-2007, 07:32 AM
  4. 28mm studded tires?
    By marc180 in forum Commuting, Touring and Ride Reports
    Last Post: 01-24-2007, 10:52 AM
  5. Will an '05 Veloce take 28mm tires?
    By Metaluna in forum Bianchi
    Last Post: 09-14-2006, 06:33 PM
