Will a 25c tire on a 19cm rim ≈ 23c tire on 24cm rim?
Results 1 to 5 of 5
    Jan 2014
    Will a 25c tire on a 19mm rim ≈ 23c tire on 24mm rim?
    It seems like from what I've read, a 23c tire on a wide (24mm) rim will measure closer to 25c. If I have wide rims (24mm) and want to race on 25c tires, would it be better to go for 23c tires since they will measure close to 25c while the actually 25c tire will measure closer to 28c? Thanks for your help, I'll try and link to a couple examples of where I got that info.
    Source1: "If you put a 23mm tire on a 19mm-wide rim, it will measure narrower than the same tire on a 22mm-wide rim."- Choosing your tire width - Slowtwitch.com
    Aug 2010
    If you have a 24 CM wide rim it's definitely not for a bicycle ;)
    24CM = 9.44 inches....
    As a side not I'm not sure why some tires are labeled 25c instead of 25mm.
    Jan 2014
    Hahaha ****, I should have caught that! Thanks for pointing that out.
    Jan 2010
    Implications of Rim Width - Slowtwitch.com
    The 17C designation refers to the internal width in mm. Probably a 23-24mm outside width will be a 17C rim.
    Although just outside the recommended area on the table, a 23mm tire is fine on a 17C rim and will measure about 25mm actual. You should treat the tire pressure as if it were a 25mm tire, so 100 psi max.
    And as you say a 25mm tire will end up closer to 28mm. This is a combo I have.
    There's sometimes a buggy.
    One.
    Reputation: looigi's Avatar
    Nov 2010
    ^^^pretty much^^^ I wouldn't hesitate to go to 110 or even 120 psi, but there's rarely need or benefit in doing so.
    ... 'cuz that's how I roll.
  1. Low profile cx tire or widest road tire with SRAM red brakes
    By SBard1985 in forum Wheels and Tires
    Last Post: 09-01-2013, 01:23 PM
  2. Staggered tire sizes and bike computer tire size setting
    By Solopc in forum Wheels and Tires
    Last Post: 11-18-2012, 07:39 PM
  3. TIRE REVIEW: Roubaix Armadillo Elite Tire vs Continental Gatorkin
    By stevepeter83 in forum Wheels and Tires
    Last Post: 07-24-2012, 04:06 AM
  4. swap new tubular tire to rear and put 'risky' tire on front?
    By SinnerDC2 in forum Wheels and Tires
    Last Post: 07-30-2010, 07:42 PM
  5. Replies: 9
    Last Post: 05-16-2010, 05:18 PM
