Will there be much difference in carbon rim design for disc brakes and rim brakes?
Results 1 to 5 of 5
    wyrd bi ful rd
    Reputation: c_h_i_n_a_m_a_n's Avatar
    Mar 2012
    Question Will there be much difference in carbon rim design for disc brakes and rim brakes?
    Side walls on the disc brake rim slightly thinner or not significantly different? Clincher tyre use that is.
    If tubular, then due to the 'boxed' design, does that mean thinner walls?
    Material around nipple hole needs to be further strengthen? Due to additional torque from the hubs?
    Reputation: bwbishop's Avatar
    Sep 2011
    All else being equal the torque should be the same. The rim should be much lighter because there is no need to support lateral compressive loads where the brake track use to be.
    The weight savings in the rim should offset some of the weight gain from the disk, especially since you're losing weight at such a large radius and gaining it at a small radius.
    Reputation: looigi's Avatar
    Nov 2010
    Not sure what the effect on design will be but the torque exerted by a disc brake and transferred through the spokes to the rim is pretty high, high enough to lock the front wheel with effectively all your weight on it. That's more than you can put out pedaling.
    No heat input to the rim from braking changes the material requirements, so perhaps heat resistance can be traded off for other beneficial material properties.
    ... 'cuz that's how I roll.
    Sep 2005
    Initially ... no. This is because it will be easier to use existing rims than design new rims and have two lines (one rim brake, one disc brake).
    Down the line when disc brake equipped bikes become more and more available/popular ... rim designs will change. For an idea of how, look at the MTB market. Initially, rims didn't change but as they became the standard in brakes ... the rims changed and got lighter and stronger at the same time.
    I think it will happen faster in the road world because much of the rim designing has already been done in the MTB world, but they have more room to design with aerodynamics in mind.
    Voting isn't marriage - it's public transport. You are not waiting for "The One" who is absolutely perfect. You are getting on the bus, and if there isn't one going exactly to your destination you don't stay at home and sulk - you take the one going closest to where you want to be!
    Cranky Old Bastard
    Reputation: Randy99CL's Avatar
    Mar 2013
    Quote Originally Posted by looigi View Post
    I've got road disc wheels now (cross bike) and am researching having a new set built.
    I really wish someone would do a scientific test of how much stress a disc brake puts on the spokes and nipples.
    It is confusing to me because DT recommends their SuperComp spokes for disc wheels and they are the lightest they make at 14-17-15. I would guess that a 15ga nipple is easier to pull out of than a 14??
    At least a half-dozen companies are selling 29er disc wheels with 24 spokes in the front, 2x or 3x. Most are double-butted. Until I saw these I would have guessed that less than 32 was a mistake.
    At this point I'm planning on 24F/28R with Sapim Lasers for a set of road wheels with 25s.
    As I've said, I wish someone would do some testing and give us some spoke stress numbers.
    "When you know absolutely nothing, anyone who knows 1% more than nothing sounds like an expert."
  1. Disc Brakes
    By jays35 in forum Tandems
    Last Post: 07-05-2013, 04:10 PM
  2. Disc brakes with carbon rims, When can we expect to see them
    By freezin_is_the_reason in forum Wheels and Tires
    Last Post: 11-17-2012, 01:23 AM
  3. Disc brakes needed for carbon wheels? X-post from wheels
    By onespeedbiker in forum Components, Wrenching
    Last Post: 05-29-2012, 08:42 AM
  4. Disc brakes needed for carbon wheels?
    By onespeedbiker in forum Wheels and Tires
    Last Post: 12-16-2011, 09:11 AM
  5. Carbon fiber cyclocross with disc brakes?
    By hardwarz in forum Cyclocross
    Last Post: 06-16-2010, 07:01 PM
