Worn carbon brake track?
Results 1 to 8 of 8
    Jan 2016
    Hi all, I just bought these Chinese carbon wheels used and am concerned that the rims may be worn out. A bike mechanic friend of mine (6 years, ex cat 2 roadie) says that they are good to go but I am still concerned. Call it paranoia, but I would appreciate a second opinion. Let me know if different pictures are necessary. Thanks in advance for your input.
    Attached Thumbnails Attached Thumbnails Worn carbon brake track?-img_5449.jpg   Worn carbon brake track?-img_5455.jpg   Worn carbon brake track?-img_5453.jpg
    changingleaf
    Aug 2009
    I don't see a brake track on those rims. They look like they are disc specific. If they are designed for disc brakes without a rim brake track they are no good for using with rim brakes.
    Sep 2011
    I would contact the seller/mfg. If the are Ebay wheels you are probably out of luck but if they are were purchased from a reputable Chinese company they may back up their wheel. I put over 2000 miles on my new Chinese wheels in 2018 and my tracks aren't shiney like that. What are you using for brake pads? Mine came with 2 sets from the mfg (Far Sports).
    'brifter' is a lame word.
    Quote Originally Posted by changingleaf View Post
    ??? Are we looking at the same photos? Looks like there is a small amount of wear.
    I work for some bike racers
    and a bunch of skateboards
    Jan 2016
    So the rims are slightly worn but still have a significant amount of miles left in them?
    Sep 2011
    look a little worn but looks quite ride-able, especially on the flats
    ngl
    ngl is offline
    Jan 2002
    The marks look like they were made from grit embedded in the brake pads. I would purchase and install new carbon-specific pads and ride them. I inspect and clean my carbon wheels and brake pads every couple of rides just to monitor any abnormal wear.
    Also, never run aluminum wheels using these carbon-specific pads. If you want to alternate between carbon and aluminum wheels make sure you change your brake pads too.
    changingleaf
    Aug 2009
    There's a different photo showing now than there was before. Strange.
    I would check to see if the brake surface is concave. The center of the brake surface will typically wear more then the edges.
  1. ENVE SES 3.4 textured brake track worn normal?
    By agravic in forum Wheels and Tires
    Last Post: 09-07-2012, 05:04 AM
  2. How to tell if carbon brake tract is worn?
    By eecc in forum Wheels and Tires
    Last Post: 03-13-2012, 02:21 PM
  3. Tricross Brake Bosses Worn?
    By Mtn2RoadConvert in forum Cyclocross
    Last Post: 04-03-2011, 09:51 PM
  4. (New) Instantly worn brake pads...
    By SmuGGums in forum Components, Wrenching
    Last Post: 09-22-2009, 04:29 PM
  5. Replies: 12
    Last Post: 03-24-2004, 11:31 AM
