your favorite light weight, all-weather 700 x 28 to 700 x 32 tire
Results 1 to 10 of 10
    Reputation: Henry Chinaski's Avatar
    Currently running Jack Brown Greens (295 grams). They roll pretty good but 700 x 33 feels like riding on basketballs. Thinking of getting some 700 x 28 Conti 4 seasons which are 260 grams (have the 700 x 25s on another bike and dig them). But what do you guys like? I'm in Seattle so those get ridden in the rain. A lot. Thanks.
    Jack Brown GREEN 700c x 33.333 Light - 10091 - GREEN
    Continental Bicycle -Grand Prix 4-Season
    Online Wheel Builder
    Reputation: Zen Cyclery's Avatar
    Mar 2009
    I think the GP 4 Season is a great option. I run that tire in a 25c and I've found it to be pretty durable. They definitely aren't as supple as my Vittorias but I think they're a better option for rough roads. I think 28c is the biggest I'd go for most applications other than touring.
    Quote Originally Posted by Zen Cyclery View Post
    Thanks. I like the width and bigger contact patch for the rain, especially over crummy pavement (with leaves and stuff) in the dark.
    Vittoria Paves come in 27mm now if you could go that small. They are fantasitc riding tires but not sure if they fit what you are looking for. They're pretty rugged but definitely more a performance tires than something you'd probably want to slap on a unilitarian type bike.
    Reputation: GRAVELBIKE's Avatar
    Sep 2011
    Panaracer Gravelking in 28mm are some of my favorites. When mounted on 25mm (HED, in this case) rims, they measure 30.5mm. Smooth, fast, and grippy.
    GRAVELBIKE.COM - ride everything
    Quote Originally Posted by GRAVELBIKE View Post
    Cool. Was thinking of speccing out a new frame with those Grand Cru calipers as well.
    Sep 2011
    Quote Originally Posted by Henry Chinaski View Post
    Depending on which levers you'll be using, you may also want to consider the TRP RG957 calipers. I'm running SRAM Force 22 levers, and the TRPs are a slightly better match for the SRAM's cable-pull/mechanical advantage.
    Feb 2002
    Contact patch size is determined by tire pressure, not tire size. The contact patch shape changes with tire width, but the size is the weight on the wheel (in lbs.) divided by tire pressure (in psi). Simple as that.
    Sep 2005
    Currently ... The Bontrager AW2 in 28c size.
    I've rode Gatorskins and Panaracer RibMo's recently and much prefer the Bontragers. They roll faster, have better traction and better flat resistance than the others.
    Voting isn't marriage - it's public transport. You are not waiting for "The One" who is absolutely perfect. You are getting on the bus, and if there isn't one going exactly to your destination you don't stay at home and sulk - you take the one going closest to where you want to be!
    Dammit Kerry!!!
    I'm running the Jack Browns at 70 psi which I can't do with a 700 x 25
  1. How to put extra weight on light weight bikes
    By solideric in forum Pro Cycling - Tour de France
    Last Post: 02-27-2014, 07:21 PM
  2. Is there a light weight, grippy 28mm tire for wet
    By bikerneil in forum Wheels and Tires
    Last Post: 11-15-2010, 08:08 AM
  3. I looking for a good light weight clincher tire
    By AlexCad5 in forum Save Some Weight
    Last Post: 06-14-2008, 02:33 AM
  4. Replies: 3
    Last Post: 07-18-2007, 04:46 PM
  5. favorite light tire/tube
    By b987654 in forum Save Some Weight
    Last Post: 08-16-2006, 10:12 AM
